Re: Re: Re: Re: Re: 300 Utility Hydraulics: Hot Oil and Chatter
Posted by dick on August 07, 2002 at 20:40:07 from (209.245.10.77):
In Reply to: Re: Re: Re: Re: 300 Utility Hydraulics: Hot Oil and Chatter posted by Kilian on August 07, 2002 at 09:51:40:
Assuming the valve you're referring to is the regulator and safety valve we've been discussing, I imagine that the only parts you'll need for fixing what's wrong should be a gasket (3) and, possibly, an O-ring (4). The piston and seat should be OK if you're not having problems moving a load; they really don't figure into the unloading problem you seem to be having.
On the cross-check valve, first make sure your hoses are hooked up correctly - rotating the handle on the control valve forward (control shaft rotates same way as tractor wheel when the tractor is moving forward) has to lift the hitch, not vice versa. If this is correct, then you probably just need a new O-ring - if you can get to it.
Post A Followup
: Re: Re: Re: Re: Re: Re: 300 Utility Hydraulics: Hot Oil and Chatter
