Re: wheel weights, inside or out?
Posted by Bill Smith on August 07, 2002 at 22:22:04 from (128.242.4.59):
In Reply to: wheel weights, inside or out? posted by John S-B on August 07, 2002 at 19:35:03:
Your tractor is more stable with caste iron centers of wheel dished out and slid out to the end of axle and with wheel weights mounted on the outside of wheels. Any other way will bring center of gravity closer to center of tractor, loosing stability. Mounting weights on inside of wheel doesn't seem like much difference but take a 15 pound sledge hammer and hold it next to your body and then hold it with your arm fully exstended outwards. It is alot harder to hold up with arms extended outwards. Same thing apply's when adding weight to the axle. It is alot harder to raise that 100 lb wheel weight at the end of the axle than it is right up close to the tractor. That is what gives you stability. If you are looking for stability I would mount both wheel weights to the outside of wheel.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
