Re: wheel weights, inside or out?
Posted by John A on August 08, 2002 at 19:54:03 from (208.24.233.9):
In Reply to: wheel weights, inside or out? posted by John S-B on August 07, 2002 at 19:35:03:
John S-B, It won't matter at all if that is all you are adding! My ol M has 2 set on it , and will add 1 more shortly. Yes stability is better when the wheels are cupped out. Unless you are working your tractor one set is plenty to derss up the wheels. I have seen old Ms in the TX panhandle with Foundry made inside and outside cast weights They are really sharp looking, but these combos add about 600 lbs,on each rear wheel. It boils down to how much wt do you need to keep your tractor on the groung, not hopping or spinning excessily. How much work are you willing to do , to place it in the poisition you want it! Good luck, John A.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
