Re: Re: 1066 steering problem
Posted by K.B. on August 10, 2002 at 10:21:55 from (209.163.14.42):
In Reply to: Re: 1066 steering problem posted by Hugh MacKay on August 10, 2002 at 02:34:49:
Yep, 3 separate pumps. Theres the hitch pump for the 3-point and the remote valves; the MCV for the steering, brakes, and TA; and the PTO pump for the PTO clutch. Check out the brakes and TA to confirm that the MCV is working.
Post A Followup
: Re: Re: Re: 1066 steering problem
