Diesel engine running away
Posted by John in CT on August 10, 2002 at 18:28:28 from (64.252.76.95):
I have an old Hough Payloader with an IH UD9 engine, starts on gas , runs on diesel. It has been sitting for about 25 years. I rebuilt the carb, and did run it on gas. It ran pretty well, {I did dump the old oil and filter}. It didn't smoke at all. I changed the fuel filters (they were real dirty and I suspect the injector pump wasn't getting fuel), cleaned the prefilter and drained the fuel tank. I put in fresh fuel. When I started it this time, it smoked pretty bad while in gas mode. It seems to be getting diesel fuel somehow. When I switched over to diesel mode, the engine took off on its own revving very high. I immediately shut it down. Is there something sticking in the injector pump? Is anything serviceable from the side pump cover? Thanks John
Post A Followup
: Re: Diesel engine running away
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
