Re: IH 240 FAST HITCH
Posted by K.B. on August 11, 2002 at 19:41:27 from (209.163.14.220):
In Reply to: IH 240 FAST HITCH posted by SSSEWARD on August 11, 2002 at 07:31:11:
Traction Control basically transfers weight from the implement you are pulling to the rear wheels, adding traction. Plowing is a good example of a time when you would use it. The lever selections vary the sensitivity/amount of weight transfer. An owners manual could explain it better. As for the steering, I've never rebuilt one, but I do have the 200, 230, 240 parts book that has an exploded view of the power steering unit, so I can probably help with any questions that you might have.
Post A Followup
: Re: Re: IH 240 FAST HITCH
