Re: More M 12v wiring questions
Posted by Bob M on August 12, 2002 at 08:42:00 from (165.170.128.66):
In Reply to: More M 12v wiring questions posted by O2Wheels on August 12, 2002 at 07:51:41:
The alternator BAT terminal is the power ouput connection - it supplies current to the electrical system whenever the alternator is operating.
You WILL need to add a warning light (or an electrical equivalent) in the #1 line in order for the alternator to work. I prefer a warning light myself - it works same as the alternator idiot light your car. However you can substitute the electrical equivalent of a 10 to 40 ohm, 5 watt resistor and/or a diode in place of the lamp if you prefer. (If you don't add a light or resistor, the engine won't shut off when you push in the ignition switch.)
When you are finished you should have only 3 wires connected to the light switch: The supply from the ammeter, a wire feeding the headlights, and another wire feeding the rear light.
Post A Followup
: Re: Re: More M 12v wiring questions
