Re: Re: Re: Re: 1 Wire Alternator?
Posted by Simp on August 14, 2002 at 10:36:24 from (209.240.198.63):
In Reply to: Re: Re: Re: 1 Wire Alternator? posted by Doug in OR on August 14, 2002 at 09:45:32:
If it is a true 1 wire alternator, the regulator energizes the alternator to start the charging process. If you are getting feedback that runs the battery down ovrnite, either you have a bad or incorrect regulator. Also. if it doesn't charge, maybe the rpm's are not enough to energize it. Another thing to check if it had a positive or negative ground, you may need to switch the wires around on the amp gauge terminals. You can tell by the amp gauge working in reverse of what it should. Also make sure the gauge is good. I've seen many bad amp gauges. Hope this helps.
Post A Followup
: Re: Re: Re: Re: Re: 1 Wire Alternator?
