Re: 1066 HYDRAULIC FILTER
Posted by RPM on August 20, 2002 at 09:19:58 from (63.110.182.225):
In Reply to: 1066 HYDRAULIC FILTER posted by Mitch - MS on August 20, 2002 at 08:26:42:
Stop using the tractor, determine what Hytran looks like, if it has metal filings (and I would bet it does) dont run it anymore or you will trash hydraulic pumps at least, would suspect a multitude of problems, could be bearing somewhere, like axle bearing, or could be spider gears in diff case, It is nothing that will go away until you get it fixed. The Hytran is common lube for entire rear of tractor so if its contaminated it will circulate all systems except engine. It cannot be brakes on 66, but it could be bearings on brake pinion shafts. 86 had brakes that could plug filter.
Post A Followup
: Re: Re: 1066 HYDRAULIC FILTER
