Re: Tire Size for Diamond tread ???
Posted by gene b on August 21, 2002 at 18:19:44 from (63.25.167.40):
In Reply to: Tire Size for Diamond tread ??? posted by Ken Jorgensen on August 21, 2002 at 05:44:30:
you need to measure your rims as the turf type will say on the sidewall which size rims and tire size go together most 8.3x24 turf will say on a 7in rim remember that the outside dim on the rim need to subtract 1in if the width measures 9 it will be an 8in rimthat is the rule of thumb a 9.5tire will mount on an 8in rim usually but the tire will say on the sidewall which rim measurement is correct this is important for turf tires so the radius on the cross section when mounted is the right crown for mowing to carry the weight and traction have an A with 7in rims and 8.3 turf work great
Post A Followup
: Re: Re: Tire Size for Diamond tread ???
