Re: 1566 wont move
Posted by Red Baron on August 23, 2002 at 05:57:15 from (165.139.135.249):
In Reply to: 1566 wont move posted by Fred (again) on August 22, 2002 at 19:27:54:
First check the hydraulic filter. It is probably full of metal. I had a 1566 do this same thing. I stopped to open a gate and when I went to move again it just sat there. No noise of any kind to indicate any problem. Found out that the cross in the differential broke, had to replace the whole complete unit than worked fine.
Post A Followup
: Re: Re: 1566 wont move
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
