Re: Front end rebuild on an H... Help...
Posted by RPM on August 23, 2002 at 07:20:30 from (63.110.182.225):
In Reply to: Front end rebuild on an H... Help... posted by Slappy on August 23, 2002 at 05:54:22:
This was common on H/M thru 450 design front steering, they simply wear out the bushing and wear the shaft, just replacing the bushings wont cure the fit-up, you have to either replace the shaft or have it rebuilt up to right size, H bolster shaft are more prone to break right at the neck above lower bushing.
Post A Followup
: Re: Re: Front end rebuild on an H... Help...
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
