Re: Now I own a B250 Diesel,story and questions INC.
Posted by Hugh MacKay on August 24, 2002 at 14:12:50 from (216.208.58.161):
In Reply to: Now I own a B250 Diesel,story and questions INC. posted by Michael Soldan on August 24, 2002 at 13:48:17:
Sounds like a quite decent buy Mike. That little diesel is similar in lots of ways to your Farmall Hs, with 5 speed, standard pto. Big difference being the diff lock, 3 point hitch and disc brakes. Your Hs probably have band brakes. My dad had one of the later Hs, it had disc brakes.
As I said before enjoy until Oct.-Nov. then put it away for winter unless you can guarentee another Jan.- Feb. like this year.
Post A Followup
: Re: Re: Now I own a B250 Diesel,story and questions INC.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
