Re: Now I own a B250 Diesel,story and questions INC.
Posted by Scott AR on August 24, 2002 at 20:32:42 from (209.194.159.159):
In Reply to: Now I own a B250 Diesel,story and questions INC. posted by Michael Soldan on August 24, 2002 at 13:48:17:
Sure glad you didn't run thru the end of the barn. I have a small suggestion for your clutch problem. If you have an inspection door and a squirt can with some light oil and put just a little bit on the splines of the shaft right behind the clutch disc it will help it loosen so it can release. Keep in mind you don't want so much oil that it gets on the pressure plate or the disc facings.
Post A Followup
: Re: Re: Now I own a B250 Diesel,story and questions INC.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
