Re: M Farmall Clutch
Posted by Michael Soldan on August 26, 2002 at 04:38:23 from (216.46.130.27):
In Reply to: M Farmall Clutch posted by JIM on August 26, 2002 at 03:42:43:
Jim, the fingers on the clutch can be adjusted from under the belly pan, or if you have a lft all,you may have to remove it. The fingers are on jam nut and bolt,loosen the jam and turn the bolt in .you will see the fingers move out as the bolt turns in..leave about 3/16 between the finger and the bearing..at least adjust them all evenly. I had this problem with an H and that's all it took..hope it is a simple fix for you..Mike in Exeter Ontario.
Post A Followup
: Re: Re: M Farmall Clutch
