Re: Baler Engine Verses A Engine
Posted by Hugh MacKay on August 27, 2002 at 01:24:49 from (216.208.58.101):
In Reply to: Baler Engine Verses A Engine posted by Montana Dan on August 26, 2002 at 19:55:29:
I cant answer much of what you ask. I do know however that a SA will run a baler provided the pulling is not too difficult. We used SA a lot of years baling straw behind thresher as a stationary unit. Have even baled some hay on flat ground. This was only done a few times when other tractors were busy.
Post A Followup
: Re: Re: Baler Engine Verses A Engine
