Re: Re: Re: All set to mow and now tractor stalls
Posted by Justin NY on August 27, 2002 at 17:31:57 from (12.30.224.206):
In Reply to: Re: Re: All set to mow and now tractor stalls posted by Gramps544 on August 27, 2002 at 13:38:47:
Gramps,
A very good possibility is the vent in your gas cap is plugged,Just try checking the vent on your gas cap and see what happens it could be that easy of a fix!!What happens is after the tractor starts running and using the gas in tank the vent ( if blocked) won't allow air back into the tank to replace the gas that was used and it creates a vaccum inside your tank and won't allow fuel out of the tank!!!!Kinda like trying to pour gas out of your gas can when you don't open the little breather cap= It won't pour out easy! Good Luck,
Justin
Post A Followup
: Re: Re: Re: Re: All set to mow and now tractor stalls
