Re: Re: All set to mow and now tractor stalls
Posted by Gramps544 on August 27, 2002 at 13:38:47 from (64.105.216.218):
In Reply to: Re: All set to mow and now tractor stalls posted by Steven@nd on August 27, 2002 at 13:22:16:
Yes I agree with the choke adding more gas to the air/gas mixture. Then I would be running to lean. It will start again with the choke closed. I will try richening the mixture. If it restarts, I do not see how that could be the coil or an electrical problem. I replaced the cap, rotor, wires, etc. this winter.
What I do not see is if it running to lean, why after 20 mins or so it stalls out? Is this anything to do with vapor lock? I do not know what vapor lock is. I assumed it was something like to much air in the mixture not allowing the gas to burn.
Post A Followup
: Re: Re: Re: All set to mow and now tractor stalls
