Re: H bolster rebuilt, some play present
Posted by Bob M on August 28, 2002 at 09:07:01 from (165.170.128.66):
In Reply to: H bolster rebuilt, some play present posted by Carey on August 27, 2002 at 19:26:24:
Carey - If the steering is right there should be only a slight amount of backlash between the worm and sector gear - about 1" of free travel measured at the steering wheel rim is good. Before your spend $$$ to replace the gears, consider this experience I had: My Super H had sloppy steering caused by excessive backlash between the worm and sector, and by badly worn pivot shaft bushings. While installing the new bushings I discovered the bearing surface at the upper end of the pivot shaft was worn considerably - probably 0.020" undersized. So even with a new bushing shell in place, radial play from the undersized shaft left the sector gear to far away from the worm for a good mesh. It also let the sector gear move for and aft slightly which compounded the backlash problem. To correct I removed the new bushing shell, then reinstalled it with some thin brass shim stock between the OD of the bushing shell and the ID of the upper bolster casting. I positioned the shim to move the sector gear closer to the worm. Took a couple of tries to figure out the correct thickness and width for the shim, but when finished all the radial play at the top of the pivot shaft had been eliminated and the backlash observed at the steering wheel had been reduced from 6" to about 1". And it only cost me a couple bucks for a small assortment of brass shim stock.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
