Re: M Farmall Clutch
Posted by Jim on August 28, 2002 at 09:36:08 from (216.43.103.151):
In Reply to: M Farmall Clutch posted by JIM on August 26, 2002 at 03:42:43:
Thank you for the help. I hope 2 squirts of grease will do the trick. I already did reset the fingers but probably closer than I should. About 1/8 inch of play between finger bolts and throwout bearing. That did help some. Also one of the bolts was not even. This is a 52 M with 12 inch clutch. There are no lock nuts on the finger adjustment bolts. Jim
Post A Followup
: Re: Re: M Farmall Clutch
