Re: BobM...electrical help please
Posted by Bob M on August 28, 2002 at 17:16:36 from (24.169.120.138):
In Reply to: BobM...electrical help please posted by DaveJ(WI) on August 28, 2002 at 15:29:55:
Dave - Simplest solution is to replace the existing button ignition switch with a DPDT toggle switch, as shown in diagram #7 in the link below. Another way is to use a single wire 10SI alternator (diagram #9), However single wire alternators are more expensive, and have some functional drawbacks over their 3-wire cousins.
You could also add a relay and swap the existing N.C. ignition switch with an N.O. switch, but you then add complexity (and cost). My advice is to keep it simple and use a toggle switch!
Post A Followup
: Re: Re: BobM...electrical help please
