Re: Re: What are you using to sand Blast with?
Posted by Bruce christian on August 29, 2002 at 15:41:13 from (24.196.206.91):
In Reply to: Re: What are you using to sand Blast with? posted by IHBRAD on August 28, 2002 at 14:15:10:
About the same thing we used, but it was a bit stouter tank, 1/4" wall. Watch your pressure on that tank over time. My brother uses a clemco 600lb tank with diesel 200cfm compressor. I use a small craftsman 80lb siphon with a 23 cfm Puma compressor and it works fine for what i need.
Post A Followup
: Re: Re: Re: What are you using to sand Blast with?
