Re: Re: Re: C axle housing/transmission leak
Posted by Haas on August 30, 2002 at 04:14:12 from (166.72.245.249):
In Reply to: Re: Re: C axle housing/transmission leak posted by DHuth2 on August 29, 2002 at 21:15:07:
Yes, you are correct. Should have looked at the parts book before I posted that. The inner seal is in the axle housing, so if the gasket between the transmission housing and the axle housing is bad, it would leak oil from the transmission. I agree, it looks like you can't slide out the axle housing without taking the axle loose from the bull gear, so the axle is going to have to be removed to fix the leak. If I was doing this job, I would certainly replace both of the axle seals while I was into it. I apologize for the bad info.
Post A Followup
: Re: Re: Re: Re: C axle housing/transmission leak
