Re: H shifter pin
Posted by Slappy on August 30, 2002 at 15:43:23 from (143.88.58.77):
In Reply to: H shifter pin posted by Hal Davis on August 30, 2002 at 15:09:12:
Hal, If I understand your problem correctly, it is similar to one I had on my H. The pin you refer to slides through the base of the shift leaver as well as a larger cylinder that the leaver rotates around. Basically the larger cylinder slides through an opening in the shifter base and the smaller pin slides into them both at a 90° angle. The whole thing is really very simple (despite my rambling attempt to describe it). The holes in the deck casting are on both sides and are plugged by small caps that are held in by friction. It's possible that one of the holes in the casting is really worn but more than likely when you clean out the other side you'll find they match pretty well. All three of these parts are available from you IH dealer and inexpensive. If you pull the shifter leaver out be careful not to let any of the parts fall into the opening or you will have to remove the deck to get them out. If you need a picture or part numbers I probably help. I'll be out till Tuesday. Good luck.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
