Re: F-12 Single Front wheel (cast)
Posted by John (SC) on September 06, 2002 at 13:13:43 from (206.74.216.101):
In Reply to: F-12 Single Front wheel (cast) posted by Stevie on September 05, 2002 at 18:15:57:
not exactly sure but i think the surfaces you speak of ar the races and should be able to get those out.I think there are two bearing on the shaft one on each side of the hub but nit sure,I hqavent been into mine yet so I really dont know.There should also be a dust cover on the outside of the shaft on each side of the wheeel,at least thats the way mine is.
Post A Followup
: Re: Re: F-12 Single Front wheel (cast)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
