Re: How do you adjust carb on cub????
Posted by clark on September 08, 2002 at 10:30:07 from (64.12.97.13):
In Reply to: How do you adjust carb on cub???? posted by Billy Lundstrom on September 08, 2002 at 09:33:45:
HI Bill, first of all the white demonstrator cub's didnt come out till early 1950.., there werent any 49 demos.. to answere you question about the adjustment on the cub carb is that the only real adjustment is the idle jet.. these IH carbs are prone to warpage from over the years of being taken apart and put together and screws tightened too much.. the thing to do is get a kit and take your carb apart ,, check all mateing surfaces for flatness.. if they are warped you possibly can fix the problem with a flat file enough to get the surfaces to fit tight enough for the gaskets to seal.. also check to make sure that the main jet hasnt been drilled out, if it has it willneed sodered and redrilled to proper size, then make sure the idle tube isnt broken off, if it is then you will have to replace it but getting the broken piece out of the top of the carb is a real challange..i would sudjest goint to atis under the farmall cub discussion board and loking in the arcives and finding out about replaceing the needle valve with a rubber tipped one, this will work great in stopping the leaky carb problems .
Post A Followup
: Re: Re: How do you adjust carb on cub????
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
