Re: Temp Gauge on 806
Posted by KX on September 10, 2002 at 13:13:10 from (66.129.8.2):
In Reply to: Temp Gauge on 806 posted by Ken T. on September 09, 2002 at 16:47:27:
Ken,
I wouldn't go throwing 100 to CIH. Unless this is a show tractor, you just want to know temp right? Go to Autozone and buy a temp guage, it will mount in your dash and the sensor bulb will screw into your manifold if not like it is, they include fitting adapters in the guage. The coil shielded wire from the sensor to the guage isn't going to be as heavy duty as CIH but you can route it and tie it where it should last for years and not get snagged etc. Besides that you are going to spend about 10% what CIH gets. Good luck.
Post A Followup
: Re: Re: Temp Gauge on 806
