Re: H carb problems
Posted by The Red on September 11, 2002 at 05:00:03 from (12.84.239.153):
In Reply to: H carb problems posted by dumas on September 11, 2002 at 04:52:09:
You should be getting a good stream through the line. Remove the fuel strainer bowl and turn on the gas valve. If you only get a slow trickle, then the inlet pipe on the fuel strainer probably has a restriction in it.
Post A Followup
: Re: Re: H carb problems
