Re: Re: Re: 44 Farmall A Distributor
Posted by gene b on September 11, 2002 at 13:29:50 from (63.15.134.202):
In Reply to: Re: Re: 44 Farmall A Distributor posted by John Martin on September 11, 2002 at 12:51:05:
from your latest post you have a mag dont go messing with those teeth the rotor has to line up with the post on the cap if your engine isa running and it must be from your post everything is ok THE MAG RUNS AT 30+ DEGREES WHEN ENGINE IS RUNNING
Post A Followup
: Re: Re: Re: Re: 44 Farmall A Distributor
