Re: Char-Lynn P.S. on SMTA
Posted by Bob in Southeast Nebraska on September 11, 2002 at 14:24:25 from (162.40.71.179):
In Reply to: Char-Lynn P.S. on SMTA posted by Robin Broders on September 11, 2002 at 09:15:49:
I use power steering fluid in my char-lynn power steering units. I have had to replace "O" rings in the power steering motor because of leaks. If you should need to do the same just be sure that you mark the outside of the case before taking it apart as it is a must that it go back together in the same way.
Post A Followup
: Re: Re: Char-Lynn P.S. on SMTA
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
