Re: Farmall 400 engine miss (solved)
Posted by Kendall on September 12, 2002 at 12:46:09 from (207.136.21.254):
In Reply to: Farmall 400 engine miss (solved) posted by Scott(TN) on September 12, 2002 at 10:44:54:
The distributor on my Super-A was so messed up on the inside that the timing advance weights were slapping against the inside of the distributor and the shaft was rusted stiff so that it was not advancing at all. Make sure your distributor is in good shape, the shafts that the weights pivit on are not worn out and the cam rotates when the weights move in and out. If you're watching it with a timing light, its fairly normal for the timing to jiggle around a tiny bit. As for as your volt meter, hook both voltmeter and test meter to same point. If voltmeter still says 12v and testmeter says 14v, I'd say voltmeter needs calabration (some have adjustment), or replacing.
Post A Followup
: Re: Re: Farmall 400 engine miss (solved)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
