Re: Re: Farmall 400 engine miss (solved)
Posted by Kendall on September 12, 2002 at 15:08:57 from (207.136.21.254):
In Reply to: Re: Farmall 400 engine miss (solved) posted by John Martin on September 12, 2002 at 13:31:32:
The static procedure I described was out of the service manual. No mention of timing light. That procedure will set #1 at exactly TDC per specs in the book, and the distributor will handle all the advance, depending on speed. Im confused on what you are saying about the flywheel and 30 degrees. I'll look at mine when I get a chance and perhaps the mud will turn clear. Initially, it does sound like 30 d. retarded. Do the static adjustment and it will be correct according to the book.
Post A Followup
: Re: Re: Re: Farmall 400 engine miss (solved)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
