Re: Re: Re: Farmall 400 engine miss (solved)
Posted by John Martin on September 12, 2002 at 15:38:14 from (207.172.11.150):
In Reply to: Re: Re: Farmall 400 engine miss (solved) posted by Kendall on September 12, 2002 at 15:08:57:
Thanks for the reply. I'll try better with explaining the 30-degrees. I painted the timing marks with white paint to see easily with a timing light...one on the flywheel, and the one on the clutch housing dust cover. With the engine running, the light connected to the #1 spark plug, and shining the light through the hand-hole in the clutch housing, the timing mark flashes at approximately 30-40 degrees farther counter-clockwise than dead center. In other words, if you consider the stationary mark at 6-o'clock, the one on the flywheel is flashing at around 5-o'clock. This tells me that it is firing late, or retarded, by the 30 or so degrees from dead center.
The best I can get it, with the distributor rotated full away from the engine, is the 30-40 degrees. If I move the distributor toward the engine, the flashing mark on the flywheel moves even farther counter clock-wise, which I think is retarding the timing more.
Thanks again for the help.
Post A Followup
: Re: Re: Re: Re: Farmall 400 engine miss (solved)
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
