Re: 44 Farmall A Distributor
Posted by Sam#3 on September 13, 2002 at 19:03:32 from (204.213.65.89):
In Reply to: 44 Farmall A Distributor posted by John Martin on September 10, 2002 at 22:03:00:
I am just getting to this post and I've got to give you my three dollars($.02 corrected for inflation). 1. The capacitor. It's only purpose in life is contact protection. Take it out you'll run but points will burn fast. Capacitors fail three ways: short- the result is no charge in coil primary, leak- primary circuit will charge but not correctly, open- burned contacts. 2. Timing. These old engines were designed to be hand cranked. They could not safely be cranked if they fired before top-dead-center. Therefore they are static timed at TDC(open points at the timing mark). Once the engine starts and the distributor picks up speed the spark is advanced by the centrifigal device. Someone said thirty degrees was normal. You said you saw thirty degrees using using a timing light to do a dynamic test. Sounds good to go. Change the points, tie down a good capacitor and static time and you've probably done all you can. You implied the tractor was running well but short on power. Do you have a basis of comparison? An A is a pretty small unit. Do you know of a similar tractor and cutting condition to make a comparison?
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
