Re: Re: Distributor or Magneto?
Posted by Craig on September 15, 2002 at 21:50:06 from (209.131.236.55):
In Reply to: Re: Distributor or Magneto? posted by Bob M on September 14, 2002 at 16:22:19:
The impulse coupling should still work if the magneto was converted to battery ignition. The impulse coupling also retards the ignition timing from the normal running timing while starting the engine. You will break your starter when the engine kicks back OR worse yet , the engine will kick back when you crank it by hand and you could be seriously hurt if the impulse coupling is not working.
Post A Followup
: Re: Re: Re: Distributor or Magneto?
