Re: LIFTALL SYSYEM ON MY 49 H
Posted by Zonie on September 19, 2002 at 20:37:30 from (205.188.209.78):
In Reply to: LIFTALL SYSYEM ON MY 49 H posted by Ted on September 19, 2002 at 15:28:20:
Farmer bob has given you good advice but these old liftall were designed to run 30 wt non-detergent motor oil, not hy-tran or hydraulic oil.
You can get away using the hy-tran but your hydraulics will be a bit on the weak side.
Don't try to use regular 30 wt. oil as it foams up too much.
There is susposed to be a dip stick in the fill pipe, I found mine when I disassembled my lift all to replace the seals, it was laying in the bottom of the resevoir.
Good luck,
John
Post A Followup
: Re: Re: LIFTALL SYSYEM ON MY 49 H
