Re: 560 ih black smoke and white hydraulic fluid
Posted by Honkey on September 22, 2002 at 16:48:25 from (64.68.163.43):
In Reply to: 560 ih black smoke and white hydraulic fluid posted by russ on September 22, 2002 at 06:10:36:
Russ,
First thing to check for the black smoke is a clogged air cleaner.
Water in your transmission will make the fluid that milky color. A hydrualic pump that is sucking air will do it too. Change the hytran and filter and keep an eye on it. If it turns that color right away, you have a oring leaking on the suction side of the pump.
As for the buzzing, try to adjust the knobs below the dash. They can sometimes get turned to a point that make the pump bypass over relief, making a buzzing noise.
Good luck
Post A Followup
: Re: Re: 560 ih black smoke and white hydraulic fluid
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
