Re: 560 ih black smoke and white hydraulic fluid
Posted by Brian in MO on September 22, 2002 at 18:00:00 from (216.73.199.216):
In Reply to: 560 ih black smoke and white hydraulic fluid posted by russ on September 22, 2002 at 06:10:36:
You might check your pressure relief valve if some of the junk in your filter is stuck in there it would make your pump run under pressure all the time which would put the motor under a load all the time causing some black smoke and would also make a squealing noise. (mine 560 did this, this summer)
Post A Followup
: Re: Re: 560 ih black smoke and white hydraulic fluid
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
