Re: 560 ih black smoke and white hydraulic fluid
Posted by Brian in MO on September 22, 2002 at 18:11:46 from (216.73.199.216):
In Reply to: 560 ih black smoke and white hydraulic fluid posted by russ on September 22, 2002 at 06:10:36:
You might check your pressure relief valve if some of the junk in your filter is stuck in there it would make your pump run under pressure all the time which would put the motor under a load all the time causing some black smoke and would also make a squealing noise. (mine 560 did this, this summer)
Post A Followup
: Re: Re: 560 ih black smoke and white hydraulic fluid
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
