Re: Water in a 49 H ?? Long post
Posted by Zonie on September 23, 2002 at 19:58:44 from (198.81.16.188):
In Reply to: Water in a 49 H ?? Long post posted by Lenny on September 23, 2002 at 19:11:11:
I've seen some posts on this forum about the block cracking in the bore that the sleaves are in.
I have a parts H out back that had several cracks on the outside of the block around the waterjacket inspection plate.
I've not heard too much about cracked heads on the H.
Pull the oil pan and fill the radiator, see if you can find where the water is leaking.
The H doesn't have wet sleaves, they fit into a solid bore in the block.
Hope this helps
Post A Followup
: Re: Re: Water in a 49 H ?? Long post
