Re: Re: Farmall A timing adjustment
Posted by John Martin on September 24, 2002 at 08:52:41 from (209.184.210.1):
In Reply to: Re: Farmall A timing adjustment posted by Kendall on September 24, 2002 at 07:09:13:
Kendall, Unless I'm misinterpreting what you are saying, I did exactly what you suggest, and the rub block of the points is hovering over the flat between the two lobes. Moving the distributor through its range of travel gets the rub block close to either lobe, but doesn't touch either one to open the points even a little bit. No matter how you position the rotor with the distributor removed, exactly at 2 o'clock, or close to 2 o'clock, when you place the distributor back on the engine, the key (opposite end from the cap) has to exactly line up with the slot, and the slot is in a fixed position. The position is fixed with the timing marks lined up exactly and with #1 cylinder at top of compression stroke. When you wiggle the thing into position, and the key fits snugly in the slot, the rotor is going to go to the same exact position every time, based on the key to slot fit-up. I may just be dense and can't figure out what you are saying, but I'm pretty sure I'm trying your suggested technique and it just won't work. Thanks again for your help. John
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
