Farmall Tractors Discussion Board
Positive ground
Posted by Scott on August 22, 1999 at 14:35:53 from (216.88.114.91):
Can someone tell me how to determine the proper way to ground the battery, positive or negative?
I own a B, it came with no battery, a 12 V. regulator, 6 V. generator, 6 V. starter and magneto ignition. I really need help finding reference material,diagrams or pictures for wiring back to stock or with a regulator. I have an I&T manual but has nothing on elecrical. Also can someone tell me what the rotary switch mounted on steering support does,it appears to be a light switch with a sort of voltage regulator. Thank you in advance.
Post a Followup
: Re: Positive ground
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
