Farmall Tractors Discussion Board
Re: Positive ground
Posted by ltf in nc on August 22, 1999 at 16:07:26 from (206.228.213.29):
In Reply to: Positive ground posted by Scott on August 22, 1999 at 14:35:53:
Scott, if your tractor has a 12 volt regulator it was probably rewired for 12 volts. The 6 volt generator could have been modified to generate 12 volts. Take the generator to a rebuilder and have them to test it for you and determine its output. The original 6 volt starter will work fine as is. The system will most likey be negative ground. Observe the regulator closely and if the system was positive ground there should be some marking on it. You will want to polarize the system once you reassemble everything.
Post a Followup
: Re: Re: Positive ground
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
