Re: Re: Governor Problems
Posted by Aaron on September 30, 2002 at 19:47:12 from (205.188.209.78):
In Reply to: Re: Governor Problems posted by Bob M on September 30, 2002 at 07:12:45:
I agree with Bob M's third third suggestion.
If the throttle does not respond than the carburetors throttle to gov connection has become disconnected. Simply take off the pipe from gov to carb and should be a pin from the gov shaft that fits into the throttle slot on carb.
Good Luck
Post A Followup
: Re: Re: Re: Governor Problems
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
