Re: Governor Problems
Posted by Bob M on September 30, 2002 at 07:12:45 from (165.170.128.68):
In Reply to: Governor Problems posted by Dale on September 30, 2002 at 05:11:46:
Dale - Here's a few things to try: 1 - With the governor cover off does the rockshaft move to stretch the spring when you advance the throttle handle? (It should...) 2 - Remove the sloped cover (the one with the vent tube to the head) located on top of the governor riser. With the throttle handle at idle you should be able to rotate the bellcrank inside with your fingers. Check also to see if the pin holding the riser link to the bellcrank is in place. 3 - If the above checks out, the only thing left is the connection between the horizontal bellcrank shaft (inside the tube between the governor riser and the carb). Loosen the connection at the carb and make sure the dog on the shaft is engaging the slot on the carb throttle shaft.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
