Farmall Tractors Discussion Board
Re: 5288 trans trouble
Posted by hypermax on August 23, 1999 at 06:01:17 from (206.97.95.235):
In Reply to: 5288 trans trouble posted by david saville on August 22, 1999 at 21:38:48:
Try checking the multi pin connectors in the sentry harness to see if any are pushed back too far. Also depress the clutch/dump pedal and the sentry should reset. If not, the brain box may be having a "bad day". One last item to check is the hyd oil level. If its low, the sentry might not be getting accurate readings either.
Post a Followup
: Re: Re: 5288 trans trouble
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
