Farmall Tractors Discussion Board |
5288 trans trouble
Posted by david saville on August 22, 1999 at 21:38:48 from (142.165.110.86):
I have a 7288 which has the same transmission as a 5288 tractor. Sometimes the sentry throws out the shift to the odd numbers. A new sensor on top of the trans did not fix it. The light comes on when the shift fails. The problem seems worse when the tractor is cold. Any ideas? Thank you.
Post a Followup
