Re: 3 Pt. hitch on farmall
Posted by BIG JOHN on October 02, 2002 at 17:44:06 from (205.188.209.78):
In Reply to: 3 Pt. hitch on farmall posted by Jeff on October 02, 2002 at 12:09:28:
Draw Bar is the name you are looking for. It can be either the single bar that comes out in the middle of the rear end of the tractor or a bar that goes from one lift arm to the other.
There can be a problem when you use the type that connects to the lift arms. If you don't have a way to lock the arms in one possition, the towed wagon etc. can cause the arms to raise when you apply the breaks or attempt to back up. If you are pulling a PTO operated piece of equipment you will probably end up bending the PTO shaft.
Since 3 point hitchs for Farmalls are after market or home made they are all different. HAPPY TRACTORING
Post A Followup
: Re: Re: 3 Pt. hitch on farmall
