H4 magneto not firing on #4 cyclinder
Posted by walter on October 04, 2002 at 17:00:53 from (209.34.8.48):
Have 1941 modetl A... farmall.. gas with mag ignition. started up fine but misses on one cyclinder. runs on 1,2,& 3.
checked distributor cap ( new) plug wire( swapped) and rotor( news) and all is OK.
1; Swapped plug wires and turned cap around 180 and same problem ( not cap or rotor or plugs).
2. put timing light on each plug and all fired BUT #4.
3. Did not check points becuase it makes no sense to fire perfectly except for #4. I saw a slight pluse glow under dark conditions on the timing light on #4.
4. Not understanding all about magnetos and having no manual on the magnetos operation I can not understand where the problem exsits.
5. I even swapped plugs around hoping to isolate it to a bad plug.
6. Do not think a COIL would act this way if defective. AM I wrong?....
all mail is appreciated.
Post A Followup
: Re: H4 magneto not firing on #4 cyclinder
