Re: H4 magneto not firing on #4 cyclinder
Posted by Ted on October 07, 2002 at 17:07:12 from (64.12.97.13):
In Reply to: H4 magneto not firing on #4 cyclinder posted by walter on October 04, 2002 at 17:00:53:
Walter: If you have the mag removed from your tractor, turn the end thats normally inside the mag housing on the engine,keep your finger away from the kill wire lug, it bites when the mag snaps. Keep turning it until snaps to each cylinder contact position, you may see that on number four, it act differnetly then the remaining cylinder positions, does snap or doesn't stop. again hope this helps you locate your problem.
Post A Followup
: Re: Re: H4 magneto not firing on #4 cyclinder
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
